Mospeada VR-052F et VR-052T chez Good Smile Company / MODEROID
Démarré par Ratatarse, 28 Novembre 2025 à 13:09:45
Nouvelles maquettes sur du Mospeada à venir en septembre 2026 chez GSC
Les photos promo sont prometteuses, hâte de voir le découpage des pièces.
La taille est annoncée proche du 1/12, à confirmer
MODEROID MOSPEADA Stick & Ray Set
¥17,000 for the set
¥ 8,500 each
Listed as 160mm which translates to 6.3 inches.
Product Description
MODEROID MOSPEADA Stick & Ray version now available as a set of two!
From "Genesis Climber MOSPEADA,"
the Military Operation Soldier Protect Emergency Aviation Dive Auto
, commonly known as "MOSPEADA," is now available as a MODEROID plastic model!
- Designer: Shinji Aramaki! This plastic model is based on the anime design.
- Two versions: Stick and Ray.
- Head height when equipped with Ride Armor: Approximately 160mm. Various articulation points. Includes various interchangeable wrists.
- Reproduces the transformation from Armor Cycle to Ride Armor, and the leg transformation when equipped with the Riding Suit.
- The Stick version comes with a missile pod, targeting sensor, laser hound, and beam cannon as weapons. - The
Ray version comes with a 40mm beam machine gun, laser hound, and shield as weapons. -
The muzzle and stock of the Laser Hound are detachable.
- The Armor Cycle allows for the beam cannon and targeting sensor to be attached to the front cowl by replacing parts.
- The helmet visor is molded in clear plastic. Two types are included: pre-painted and colorless clear.
- Includes water-transfer decals to recreate the eye prints on the head parts and markings on each part.
- In addition to various molded colors and clear parts, some pre-painted parts allow you to recreate the color scheme close to the image in the movie simply by assembling.
*This is a set sale of two items. The packaging will be the same as the individual sales versions.
mouais, bof...
mouais, bof...
Une jolie promesse à voir la réalité du kit, septembre 2026 ca laisse du temps....
