The Junkster Pod Racer
Démarré par tiking, 21 Janvier 2019 à 10:35:05
tiking
tiking
Citation de: Bouq' le 25 Janvier 2019 à 20:34:56
Tiking, do you remember what colors you used please? ...
I used a red color primer for the base color from Hagmans. For the white areas, I used skull white from Citadel.
Citationwhat steps of painting did you apply please? From primer to weathering if you still remember
1. I sprayed painted everything with Citadel Black primer
2. Then sprayed painted the Red primer
3. Then masked the panels around the area, that I wanted to painted white. I used the same method for the black paneling and around the exhausts
3. Then I used Tamiya black panel wash for the paneling. This is usually used for Airplane weathering to bring accentuate the paneling.
4. For certain detailing, I used Citadel leadbelcher.
5. As for weathering, not really much done to it. Just adding some rust effects by using the sponge technique on various areas of the main engine and paneling.
tiking
