The Jakku Desert speeder : Ver. 1 & Ver. 2
Démarré par tiking, 23 Janvier 2019 à 19:58:33
tiking
Version One:
Ok fellows. Here is my version of the desert speeder from the new Star Wars film I mentioned earlier before. As I mentioned before, the base of this speeder was a toy version that I bought for spare parts. After seeing the Jakku speeder version put on the net, I got inspired to do a similar model but, as always, I tend to go one-step-further in my builds.
Here is the toy version, compared to the the toy version, to the real model from the film. I like the version seen for a some seconds in the desert when Rey is flying through the desert on her own speeder. As you can see below the toy version isn't all that fantastic:
Now this version of Finn's speeder, above, is ok but I did not like the gun mounts. So I had to removed them. Secondly, the thickness of the bars or braces were also a concern. They did not look good to the naked eye. So I had to completely removed them by sawing them off. I opened up the engine exhaust holes at the rear and added styrene tubings over the original bracings to hide the clumpy and glossy look of the bracings.
The one from the movie, below,  is more slender in terms of the bracing work. I like that.
The short screen capture of the one from the movie:
The netting was made of Tamiya tamiya tape. I simply used a piece of brass wire as the frame and litterally weaved the tape around and across the frame. That simple. I just love the Tamiya tapes or Scotch brand tape. As we all know that they actually make the Tamiya tapes.
I decided I wanted to make my speeder more interesing by adding some kind of equipment in the cockpit. Don't ask me what they do but since the the Jakku speeder was build by scavenging parts, then it shouldn't matter what was used or what the various parts do. Just use your imagination.
So the end results is what you see in the pics. This might not fit right with you Die-Hard Star Wars fans but just think of it as another Jakku Speeder upgrade. Thanks for looking.
tiking
tiking
tiking
Nice ! I really like this kind of models. Between SF and Mad max. (Star wars here but still...)
tiking
Citation de: leup le 25 Janvier 2019 à 18:15:58
Yeah. Not too far off but still likable and playable within the theme. Thank you.
Superbe réalisation  :number1:
Le weithering est particulièrement réussi  :aplausos:
tiking
Citation de: Jief le 26 Janvier 2019 à 09:20:34
:Merci: Glad you like the results.
Manchu
CLONEMANIAC33
Fabrice
tiking
